possibe wheel probs on fox w 17"
this didn't get much response in the wheels and tires section. there's not much traffic. wondering if by looking at the pic if y'all think it's gonna be a problem for me.
https://mustangforums.com/m_3620077/tm.htm
RE: possibe wheel probs on fox w 17"
Looks like it sticks out kinda far, you will probably need rack limiter bushings. I went with 17x8's and had no issues. 9 inch wide on the front is done everyday, but I knew 8's would fit with no mods
yeah i bought the rack limiters to put on when i get tires. i think they stick out kinda far too. but lots of people use 17x9 on front, don't know why mine look so wide.
i have no idea what the backspacing is or what conversion means. i bought them from americanmuscle.com they are four lug for 87-93. i don't know how the backspacing could be changed for the better though because they come like a quarter inch from hitting the strut. maybe i should just send them back.
Oh sorry. I thought they were five lug and you dd a conversion. Take the wheel, lay it on it's front face, take something like a yardstick or straight edge and lay it across the rim. Now measure the distance from the hub mounting surface to the straight edge. That will give you your backspacing.
i guess my question is how do other people run 17x9 on the front? since these are set back i think as far as possible into the wheelwell. they cant go in any further without hitting the strut. i could buy a used tire and see how it looks.
backspacing is 5.71 and offset is 18mm. here's a pic of a car that has same spec wheels (backspacing and offest)
http://customerpics.americanmuscle.c...=28087&id=1985
maybe it just looks weird because there are no tires on them.
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
