My 5.0 Is Shaking + IDLE Ruff
Ok guys i need help bad !,
My Car :5.0 Ford Mustang , King Cobra Clutch,Lowering Springs, Smog Pump Delete, Flowmaster Exhaust - No Cats - H PIPE, BBK CAI - Upper Pully
Problem #1: Car is idling ruff , Im guessing it has something ignition? or maybe my vaccum lines if so is it hard to replace vaccum lines my self and what is the procedure!
Problem #2: Car Shaking Aggresivley at HIGH RPM'S , And i feel like it lost power. The gear shifter shakes alot too but the whole car shakes. Now i just had the Clutch installed the guy ofcourse had to remove my Exhaust my DriveSHAFT And Tranny, Some ppl say the car is shaking from the drive shaft Monday im taking it to Mechanic to find out? Does this sound accurate?
[/align]
RE: My 5.0 Is Shaking + IDLE Ruff
ORIGINAL: shawnk007
So, your saying before the clutch swap it didnt shake and now it does? If thats the case, the driveshaft would be the first thing id look at....
and about the drive shaft... and long as its push all the way into the tranny then the 4 bolts on the rear end are nice and snug that should be your problem.. unless the shop **** it up for you then it would could be a problem... depends on how much you trust you shop... do they do good work??
http://www.muscularmustangs.com/iac.php
Do those steps and see if it fixes your idle. Easy to do so it would be an easy elimination or fix.
Wow , Alott of info thanks , Keep it coming tho lol
I cleaned the IAC And TB ... No help
Im checking the vacuum lines tommorow also
I think i gapped the spark plugs too much i just changed them 54 Is the gap , What is the proper gap 42-46? right
