650 Speed Demon
650 Speed Demon
So Im building a newer, more violent version of my 347 this winter....the fattest part of the powerbad is going to be between 5000-7000 rpm. The old motor used a 650 speed demon, which was more than adequate. But,Im thinking with this rpm range and the breathing capabilities of the top end, a 750 would be a solid investment. Any recommendations?
Old motor:
347, 10.5 comp ratio, torker II intake, twisted wedge track heat heads, trick flow stage 3 cam (.574"/.595" 236/248 dur. at .050" hyd roller)
1 5/8" long tube headers, 3" 40 series cans with dumps, topped with that 650.
New motor:
Same bottom end, cam, exhaust, but switching to a set of vic jr heads, putting it up to 10.7 comp ratio, and a port matched vic jr intake manifold.
Think this thing is begging for a 750?
Old motor:
New motor:
RE: 650 Speed Demon
Well, with the old combo backed by a 3550 tremec and 4.11 auburn diff on 10.5 mt cheaters, it ran a 13.6 at 99mph, sputtering after 1000 ft because of some unrelated timing issues. Timing's fixed now. This new combo I want to create dyno's out at around 520hp on desktop dyno, but we all know how much trust to give those gizmos.
Lord help us all if I click 'checkout' on my current summitracing shopping cart.....theres a pro shot NOS fogger setup on there......
RE: 650 Speed Demon
I like the 650's throttle response a lot though. Its got all forged internals and an aluminum flywheel, so with the midrange tw heads and that 650, it bangs the rev limiter instantaneously almost. Im just afraid it'll get that classic over-carbed bog-down the second I slam the butterflies open.
BeatnikFink
10-01-2015 08:00 PM
