BIG Mustang problems
RE: BIG Mustang problems
ok another thing....this is what is in my mustang
1991 Mustang GT
motor bored .30 over to make it 306 cu. in instead of a 302
edlebrock intake
30lb injectors
75mm throttle body
block is from a 70's mustang
hurst shifter
3.73 gears
true dual flowmaster exhaust
headers
offroad h pipe
traction bars
k & n ram air kit
underdrive pulleys
the guy i bought this off of said 350+ horsepower....do u think its possible with the stuff in it???
1991 Mustang GT
edlebrock intake
30lb injectors
75mm throttle body
hurst shifter
3.73 gears
headers
offroad h pipe
traction bars
k & n ram air kit
underdrive pulleys
what could i put in it to make it 350 or more.......also i have a set of comp cams for it....and i just pulled off my valve covers again....there is machined rockers there....that wouldnt do anything for it right???besides better compression...i think
you need better heads. and im pretty sure traction bars are for leaf spring suspension so i would take those off and get some u/l control arms. get some heads with that came and intake you should be close to 300 if not right on and then throw in a bottle and call her done. if not a bottle get an s/c
