94 GT running rich on startup...
Old 08-08-2007, 11:50 PM
monkeydude3
monkeydude3's Avatar
Default 94 GT running rich on startup...
Pretty much as the title says. 1994 GT 5.0 5 speed.
It has done this since I first drove the car. I first drove it bone stock, and now it has full exhaust, K*N drop in w/o silencer and timing advance.
I start it up, and it doesnt matter hot or cold. For about 30 seconds to a minute, it runs what I believe to be extremely rich. As I accelerate, I let off it pops like absolute crazy. If I leave it in gear and let off and let it coast, it pops real bad too.
After this minute, it runs perfectly fine, I can let off in gear without a single pop.
Is this a common problem to the 5.0L? I have done plugs, wires, cap, rotor, fuel filter, and seafoamed it. Am I missing something? Dirty MAF? Something up with a sensor somewhere? Dirty injector?
Thanks in advance!
monkeydude3 is offline
Old 08-09-2007, 06:57 AM
monkeydude3
Default RE: 94 GT running rich on startup...
BUMP! I can't be the only one to run into this...
Old 08-09-2007, 10:27 AM
blkonblk5.0
blkonblk5.0's Avatar
mine does the same thing only on cold start though..but it will just backfire like once or twice
blkonblk5.0 is offline
Old 08-09-2007, 07:21 PM
monkeydude3
hmm, you think I could have some sticky injectors? Is there any cleaner I can add to the fuel that actually works and may help out?
Maybe i should take it to my school and run a motor-vac on it, where you take the two fuel lines off the fuel rail and hook them straight to a machine that runs fuel + super concentrated clean through the rail...
Old 08-09-2007, 07:39 PM
AdderMk2
Banned
AdderMk2's Avatar
check your 02 sensors and ECT sensor
AdderMk2 is offline
Old 08-09-2007, 08:07 PM
monkeydude3
will do... thing is, i dunno how the 02s could do it just at startup and then work perfectly otherwise. it's in open loop at that point and doesn't look at them...
could be the ect, maybe it's over compensating... thanks!
Old 08-09-2007, 08:37 PM
AdderMk2
Banned
AdderMk2's Avatar
if your O2 sensor heating system is not working properly, the O2's will not read properly until they reach operating temp
AdderMk2 is offline
Jb145700
08-21-2022 06:37 AM
10-07-2015 07:02 PM
heslekrants
09-23-2015 04:02 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
uedlose
09-10-2015 03:30 PM
Quick Reply: 94 GT running rich on startup...
