Oil Leak
Oil Leak
I just recently started to leak oil, and it drips down onto my Exhaust maniflod and causes it to smoke. It never did this before i changed to oil over to Royal Purple, could the Purple be causing my leak???? Im getting kinda of pissed about it[:@]
RE: Oil Leak
hey man, my car had the same exact problem. I kept tightening the valve cover, and it would work for a while, but then it would leak again. I just ended up replacing the valve cover and fixed the problem. Try Roundman's idea first, but you may end up having to replace it.
RE: Oil Leak
should i just change the valve cover gaskets? would that fix it, because sitting at a stop light and having you car smoke like a damn fireplace isn't to cool. and it is pissing me off, i cant park in the garage anymore because it will set off the smoke detector
bradleyb
11-27-2015 07:50 PM
