transmission install question
RE: transmission install question
Did youalignthe clutch and pressure plate, if not it will never go together. Or if it just won't go in try rolling the tailshaft with it in gear to turn the input shaft untill you feel it drop in place and have someone ready there with a bolt to put in.
You can start the bellhousing to trans bolts but don't use them to draw in the mixer. If you can get them started a couple of threads then it'll allow you to get the mixer sutuated a bit more then you can sort of draw it in with the bolts. THere shouldn't have to a lot of force if you're using them to draw it in.
ORIGINAL: AdderMk2
ignore ALL of the suggestions given in this thread.... have someone step on the clutch pedal as you slide the tranny the rest of the way in.
ORIGINAL: bighungrymatt
thanks adder, that did the trick!
ORIGINAL: AdderMk2
