rear end lockers. opinions please
RE: rear end lockers. opinions please
ORIGINAL: 67mustang302
The only tool you really wanna have would be a dial indicator, to make sure when you put the carrier back in the the ring/pinion backlash is correct. And an impact gun helps too, makes it go easier. but yeah, it's a pretty simple little setup, I like it. And it doesn't require any friction modifiers, just plain ol gear oil, or synthetic if you like
I was thinking about my 8", the carrier completely encloses everything inside of it, you have to take it out and actually remove the ring gear and pull the carrier open to get at the inside. Even then, it's not that difficult. I guess it'd be even easier in an 8.8"? I'm not sure exactly how they're set up
well ill see how it goes. im pretty set on the true trac at this moment. my mechanic said that he would do it for 250. im NOT a big fan on having the work done by someone else, not because of money, but because i like to say i did it. however, i dont just simply dont have the time and it needs to be done.
thanks for all the good info guys.
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
