clutch adjustment
clutch adjustment
Help,my clutch lets out at the end of pedal travel.I understand how to adjust the clutch from the quadrant but that is still not working. I know i need a new clutch but i need it to last a few more weeks. i have easy on it but is there a way to tighten it down underneath without messing it up. I know where the cable attaches to the clutch and there is a nut that looks like you can move. My buddy told me not to mess with.
RE: clutch adjustment
Do you have an adjustable cable (hence the nut) and broken/aftermarket quadrant? If so, perhaps you SHOULD touch that nut... My stock cable was non-adjustable.
Anyhow... Tightening the nut will engage the clutch sooner in pedal travel. Don't go crazy here... Try a little at a time (1 or 2 turns at most each time). You don't want the pressure plate to be partially disengaged when your foot is not on the clutch.
ORIGINAL: kaik1969
no i am talking about the two nutson the cable down by the transmission.
junior04
09-28-2015 10:53 AM
