so i finished
so i finished
installing my new injectors 30# and im going to install my 255 lph fuel pump tomorrow and then on goes the novi 1000 sitting in my room am i gonna get away without running a adjustable fpr or should i just keep my stock pump for now until i get a fpr
also where does the fpr go?
RE: so i finished
255 pump, adjustable regulator, yes to both.
the last thing you want to do is to run the car lean.
you've taken care of the injectors(and hopefully a matching MAF)
stick the pump in, install the regulator, and away you go.
even still, i hate to say it, but depending on your boost level, 30# might actually be too small.
RE: so i finished
im only gonna run 6 psi for now
damn so off comes the intake again to get to my regulator that sucks man there no way around this i cant run a stock fuel pump with 30#ers atleast until jan when i do my hci
and i have a pro m 75mm maf for 30#ers
