140 speedo install wtf
ok so i bought a 87-89 140mph speedo for $50 off this kid i kno from the car meets around here. how easy is this to do? it doesnt look that hard but i could be wrong. is there n e thing i shood look out for while im doin it?
ive seen a pic somewhere that shows how the dash comes apart but idk where to find that.
any advice/pictures/links to other threads would be helpful (tried the search thing but i cant seem to find n e thing)
thanx!
thanx!
RE: 140 speedo install
It is a straight forward swap, there are 4 screws to take out for the bezel over the speedo, the steering column cover and I think 4 more screws for the speedo as well. The light switch, hazard switch and defrost can be a bit tricky. The toughest part for me to disconnect was the speedo cable. The connections for the wires to the other guages are easy to disconnect as well.
I think you were looking for this https://mustangforums.com/m_3591186/...tm.htm#3591186
it was in the tech thread
um ok so i hooked it up but and everything works except the actual mph gauge... it works when i spin it with my hand just not when its hooked up to the car.. im confused now.. anyone have n e suggestions?
wellthat cable looks pretty secure on the tranny but should i undo it and try re stabing it?
but the little square part in the cable still turns.... clockwise
im so confused... i put the original one back on and it worked... but if i spin the back of both of them at the same rate the read the same mph but the cable wont seem turn the new one for some reason.. WTF!!![:@]
