Header gasket
RE: Header gasket
this is an old thread that i'm bringing back to life here. I see that the "old guys" say to use Mr. Gasket, where would i find those to order on the internet?? i looked for Felpro gaskets, went to the federal mogul website, and i didn't see what i needed.
I need 2 header gaskets, as i'm getting new headers soon help me out!!
-kyle
-kyle
RE: Header gasket
ORIGINAL: tchamber
I need to replace a header gasket, as it blew when a couple of bolts backed out a bit. I need to know if I can just unbolt the header from the head and slip in a new one, or will I have to disconnect the exhaust from the header as well?
RE: Header gasket
ORIGINAL: settled4automatic
-kyle
-kyle
RE: Header gasket
use antisieze compund on the bolts, you can order gaskets from
www.summitracing.com
i bought dead soft aluminum gaskets which are reuseable and they were not very expensive, you may have a hard time rebolting the headers back up they say you may need to use a pry bar to get the holes to lign up right i actually had to use a dremmel to wallow out the holes a little longer, but otherwise good luck.
RE: Header gasket
YES use antisieze never use locktight , all gaskets are going to blow just a matter of time . The meatl one do last longer . if you use lock tigh you will snap most of the bolts when you go to take them off . retighten the bolt when you change your oil an they wont blow gaskets as mutch
junior04
09-28-2015 10:53 AM
