f303 vs e303???
RE: f303 vs e303???
^^ well i dont know what you had in there before but i have a E cam and on my dyno chart it pulls strong up to 5200 rpm and does not drop off, just levels. the low end is good but its like a 25shot of n2o at about 3500rpm. my car pulls hard all the way through. i dont know how high you want to send your rpms but if its past 5500 rpm to get your peak power your going to have to make other modifications to your cars engine.
i would REALLY do some research about different cams and your set up. the simpler the better. you dont need and those heads cant generally support high lift and decent durration cam.
joel50 is right. its not about the lift. the duration is what will make your valves and pistons collide and alow more air and more fuel to be brought in. i guess lift can compinsated for duration some what, but do your homework.
PS. my brothers car dynoed at 331rwhp with an E303 and afrs.and 10.1 CR. its not a BAD cam as everyone thinks.
RE: f303 vs e303???
if you have any intentions on going fi in the future.....go with the f cam for sure. many guys making big power with the f cam....a guy on turbomustangs made over 1000whp with one....and people say the alphabet cams are garbage
RE: f303 vs e303???
alphabet cams are for little kids!!! lol get a comp cam or crane makes a godo cam too... edelbrock is so so
RE: f303 vs e303???
Crazy so the alphabet cams are for kids but the edelbrock is so so? You do realize the edelbrock cam is an overpriced e cam.
RE: f303 vs e303???
ORIGINAL: turbostang21
RE: f303 vs e303???
the heads are the only real thing that i'm dealing with. if the gt40s won't do much over .500 lift, then i'll get the e cam, but if they will handle around .512 then i'll snag a f cam.
RE: f303 vs e303???
ORIGINAL: telsonman
RE: f303 vs e303???
ORIGINAL: FullAuto
It's a turbo car. That makes it much more forgiving to junk parts. All you have to do is crank it up.
