wiring help needed
wiring help needed
I just bought a 92 ssp coupe, the car has manual windows and locks,but anyway I am having a few problems. The park lights, tail lights, and the dash lights will not work. The headlights and brake light work fine. EVERYTHING worked when I bought the car, the problem started a couple of days after I bought it. All the fuse's in the fuse box are ok, I checked the headlight switch, and all the wires are getting power through the switch(except for the one ground wire). I guess my questions is, what would be between the headlight switch and the park,dash,tail lights that could be giving me the problem? Thanks guys.
RE: wiring help needed
Have Joel5.0 get you a wiring diagram... he's pretty good at pulling that kind of info out of his rabbit trick hat I'd tell ya' but I'm not at work right now so I'don't have access to my data base
