how hard is it to install c-clip eliminators???
Old 02-01-2005, 10:43 PM
grabbem88
grabbem88's Avatar
Default how hard is it to install c-clip eliminators???
what do use,just a hacksaw? i ordered strange 31,studs,eliminators,and carrier.
i forgot to order a seal kit can i get one from napa?
grabbem88 is offline
Old 02-01-2005, 11:09 PM
grabbem88
grabbem88's Avatar
Default RE: how hard is it to install c-clip eliminators???
oh well, roundman whenever you're back online...could you help me out? thanks!!!
Old 02-01-2005, 11:29 PM
uedlose
uedlose's Avatar
I used a side cutter. or some people call it a wiz wheel.I took tape and wraped it around the tubes and used that as a guide for how much needed to come off.and to help keep things straight
uedlose is offline
Old 02-02-2005, 12:13 AM
grabbem88
grabbem88's Avatar
so it wasn't hard? what about the posi unit?
Old 02-02-2005, 12:29 AM
bobby
bobby's Avatar
yasome info guys!, im gonna get c clip elimnaotr axels soon too! is there ANY downside with c clip elm.? thanks!
bobby is offline
Stinger
Stinger's Avatar
You went with axles ?heheheh
Stinger is offline
Old 02-02-2005, 01:26 AM
grabbem88
grabbem88's Avatar
yepper i sur did,cause i'm going to take my ol'ones and wrap them around itty bitty neck!
j/k my driver side is bent worse than i thought
ORIGINAL: Stinger
Old 02-02-2005, 09:27 AM
uedlose
uedlose's Avatar
No they are not that bad to do posi-unit Iam not sure what you mean.but I got a spool in my car so it was cake.my bearings were already pressed on my axles so that was good all I had to do was cut the tubes and bolt the axles to the housing make sure you level the end of the tubes after you cut them and use lots of sealer so the ends dont leak. if that is the way yours is done.I had to leave 1/4 in on the end of the tube and that would go up into the c-clip eliminator.
uedlose is offline
Old 02-02-2005, 01:01 PM
C/Note
I ♥ Acer
C/Note's Avatar
ORIGINAL: grabbem88
its best to take out of car and bring to to rear end spec shop ,,they use a chop saw and know just how much to cut off,,and another thing is...i never seened a c- clip elimm that didnt leak!! you dont need a seal kit it should be in with the kit....should have gotting a 9inch they dont leak.............
C/Note is offline
Old 02-03-2005, 12:18 AM
grabbem88
grabbem88's Avatar
i was talking about the carrier (eaton posi).......
ORIGINAL: uedlose
Quick Reply: how hard is it to install c-clip eliminators???
