mass air meter, throttle body, # injectors?
Which one's should i get? getting ready to put motor together, very close
306 w/ sq-trim 8 psi
trickflow heads
trick intake
lunati cam
and whole bunch more ****
ALSO DO YOU GUYS THINK I'LL NEED ANY TYPE OF TUNING TO THE COMPUTER OR WILL IT RUN ALRIGHT?
trickflow heads
trick intake
lunati cam
RE: mass air meter, throttle body, # injectors?
As soon as you have it running I would have it dyno tuned. You can go with a chip, PMS, or TWEECER but I do not recomend the last 2 unless you know a little about tunning yourself. I would go with 42#, 80mm mass air, and 70mm throttle body
yah i wood go with like 36#'s or 38#'s, 80mm maf wood be over kill, 75mm maf's are good for about 700hp from what ive been told, so that shood be plenty enough and a 70mm tb sounds about rite.
ORIGINAL: sup95cobra
ORIGINAL: mdvaldosta
what he said ^^ but with 75mm tb
