6AL Install
Old 02-03-2005, 07:24 PM
titan aresta
titan aresta's Avatar
Default 6AL Install
I have an '88 LX 5.0. I'll be buying and installing an MSD 6AL ignition some time soon. My battery is in my trunk. The MSD instructions say that I need to connect the unit to the positive and negative terminals on the battery (which means I would need to get two longer cables, drill another hole in the firewall, and run the cables all the way to the battery).
Would it make any difference if I just connected the 6AL to the starter relay where the battery positive cable is connected instead of directly to the battery, and run the negative cable from the 6AL to the frame instead of back to the battery? Or would that mess something up in the 6AL?
Thanks.
titan aresta is offline
Old 02-03-2005, 07:51 PM
69mach1377
69mach1377's Avatar
Default RE: 6AL Install
Your plan is fine, that's what I did since my battery is also in the trunk. It has worked good for 5 years now. Just make sure you get full battery voltage to the box for max performance...
69mach1377 is offline
Old 02-03-2005, 08:17 PM
luckythirteen13
luckythirteen13's Avatar
ya, as long as the positive wire is connect to the battery wires and the negative is grounded, it doenst matter if your battery is in the trunk. your idea is fine
luckythirteen13 is offline
mtgldr
02-03-2024 09:00 PM
BOBCATJACK
09-14-2015 02:18 AM
09-10-2015 08:39 PM
Quick Reply: 6AL Install
