transmission speedo question
RE: transmission speedo question
1st, do a search :-)
Remember, help yourself and others will help you.
http://www.mindspring.com/~steveflye...ear_select.htm
https://mustangforums.com/m_3602030/tm.htm
Rick
Rick
thanks??? i reckon i didnt do a gear swap did a trans swap does this matter???it was correct before i changed the trans....when it read 55 i am really doing 66
Looks like your new trans has a different number of teeth on the speedometer drive gear, that is why your speedo is off. Look at the following chart to determine what you had before vs. what you have now.
http://www.ddperformance.com/Trans%20ID%20chart.htm
Rick
Rick
AmericanMuscle4.6GT
11-10-2015 02:06 PM
