What is this?
RE: What is this?
ORIGINAL: hotrodmanII
the vac line that goes though the firewall is for your a/c ducts control the solenoid by the canister??? what year we talking here..??
ORIGINAL: angcobra
Where does the vacuum line that goes through the firewall go to? What is the little solenoid for?
ORIGINAL: Obsol3te
If you tossed your smog pump you can ditch that "canister"
RE: What is this?
just put line to manifold vacumm the one going though the firewall,,,you got the right year k member ??so the shaft is to short???
RE: What is this?
Man I hope I don't run into this problem. I'm in the process of doing the exact same thing to my 1990 GT.
[IMG]local://upfiles/10184/F30BF56E953B4E549F28CA7D0CAFBCA1.jpg[/IMG]
[IMG]local://upfiles/10184/747DA791150644FB9D1F30C8D0C878E0.jpg[/IMG]
[IMG]local://upfiles/10184/80096A7519444EC9BDB643EA8A6632E9.jpg[/IMG]
RE: What is this?
[quote]ORIGINAL: 1990mustanggt
Man I hope I don't run into this problem. I'm in the process of doing the exact same thing to my 1990 GT.[quote]
Do you have the tubular K member already? Are the holes for the spring perches slotted?
