turn signals
turn signals
ok please come thru for me againi have a 92 gt and i have hazzard lights but no turn signals ive checked the fuses and changed the 1 flasher in the fuse box is there another flash for the turn signals that im not seeing?
RE: turn signals
where would i add the ground to because the turn signals are not working in the front or the back and the indicator in the dash doesnt turn on either with the turn signals but the indicator turns on when the 4ways are on
RE: turn signals
any other electrical stuff not working?..reason I asked is I have seen several cars that did this and later a few other electrical things went and all was tied to the ignition module in the steering column
RE: turn signals
FYI, I just had sort ofthe same prob...my turn signals and blower fan didn't work. Replaced my ignition switch in the steering column ($11) and they bothwork perfect. Might be worth a shot...only takes 10 minutes to install. Oh, and buy a T-27 security torx bit before you leave the auto parts store.
RE: turn signals
ORIGINAL: Rickard118
