no brakes
RE: no brakes
Vacuum does not control the amount of brake pedal you have, it just reduces the effort to apply the force to stop. If you have very little brakes, check the master for fluid first. Look behind the master where it bolts to the booster. Most times it the master is bad, it will be leaking down the front of the booster. Check the pads to make sure there is enouch material left on them, and calipers and wheel cyl for leaks.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
