good cam choice
good cam choice
I have a 94 GT with BBK shorty headers, BBK off-road-X pipe, Flow master cat back, BBK CIA, pulleys, MSD (coil,cap,rotor, and wires), smog delete kit, and will be getting a 24 lb calibrated MAF sensor and injectors with throttle body spacer and 70mm throttle body and was wondering whats best cam for mysetup? I want to go with the badest cam I can get without replacing valve springs. I'm also going to replace the upper and lower intake soon.
RE: good cam choice
My comp 270 worked good with stock heads but your gonna need an intake manifold at least before it does anything. I went 13.2 with intake, cam, longtubes, and 4.10's. Also I didn't touch the springs on the stock heads. I was only shifting at 5000rpm though.
RE: good cam choice
ORIGINAL: samseed101
You've got an SN95 5.0 so as you've probably guessed by now, a Steeda #19 is an excellent choice to keep both you and your computer happy.
