questions about a used 302
im getting a 302 efi engine and transmission out of an early 90's ford f-150, its set up for fuel injection but looks like a diferent intake set up then my 89 lx what are the differences between the two engines and what kind of numbers do u get out of the 150 engine (hp/lb-ft)
it has an automatic also, colum shifter, how hard is it to convert to on the floor and is this transmission worth keeping if i drop the engine into something else, worth getting a shift kit
RE: questions about a used 302
if the engine looks diff it probably isnt a 5.0 HO, just a non-HO. stock the numbers will be lower than the mustang ones (225hp and 300lbs tq) but if you are looking to do a HCI swap the block and internals should be just as good
well i was thinking about stripping it down from efi and maybe doing a head swap if i can find some cheap heads and droppping it into someting, preferbly an older mustang
treesloth
09-28-2015 07:03 AM
