uh oh
Old 08-19-2007, 06:17 PM
86 5.0L
86 5.0L's Avatar
Default uh oh
so I hopped in my 86 for a quick trip to the bank, get to the last turn and suddenly, I lose steering response WHILE making the turn[:@], thought great, she stalled, look down see my rpms at 1200, i yell "F*&^!!!!!" go to the bank, found out I have 0.00 in my account, yell some more, then say f*ck it and drive home, pop the hood see the belt dangaling.
It was less then 2 miles, and mostly coasting, started smelling burnt coolant, my gauge never went over L in normal, just wonder what I should check for after she cools down.
86 5.0L is offline
Old 08-19-2007, 07:08 PM
ddeaton66
ddeaton66's Avatar
Default RE: uh oh
You should be ok if she didn't overheat......need to find out why the belt decided to take a hike. Tensioner or bad/loose pulley?? Maybe just a bad belt.....
ddeaton66 is offline
Old 08-19-2007, 07:09 PM
cleanfitty
cleanfitty's Avatar
Default RE: uh oh
ORIGINAL: 86 5.0L
head gaskets... [:@]
cleanfitty is offline
Old 08-19-2007, 07:12 PM
grumpyphillips
grumpyphillips's Avatar
Default RE: uh oh
Check your coolant level and make sure you aren't leaking any coolant.
grumpyphillips is offline
Old 08-19-2007, 07:31 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: uh oh
make sure no pullies are locked up like tensioner. idler, air pump and or water pump
mjr46 is offline
Old 08-19-2007, 08:18 PM
stang8689
stang8689's Avatar
Default RE: uh oh
check oil for coolant
stang8689 is offline
