intake trouble
Old 08-20-2007, 11:30 AM
FordMustangSpeed
FordMustangSpeed's Avatar
Default intake trouble
Ok, last night i went to clean the MAF sensor and made a bad discovery. Oil coming out of the intake! I know that means engine work but i wan6ted to ask some opinions on what it may be. I'm thinkin it may be a head problem. Thanks all
FordMustangSpeed is offline
Old 08-20-2007, 11:33 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: intake trouble
it means you need to clean your PCV system
AdderMk2 is offline
Old 08-20-2007, 11:43 AM
samseed101
samseed101's Avatar
ORIGINAL: FordMustangSpeed
Sounds more like a simple PCV issue. Check the PCV valve to see if it is functioning properly. Chances are, oil is getting sucked up through the valve so you want to make sure it isn't all gunked up.
Then go to home depot and buy an Oil-Air seperator (usually used for air compressors) and install that in the vacuum line that runs from the PCV valve to the upper intake manifold. That should collect most of the oil. Just remember to check it and empty it on a regular basis.
samseed101 is offline
Old 08-20-2007, 12:57 PM
bmennen07
bmennen07's Avatar
why would he want to do that? I would think u could fix the problem and have it run like before. Not have to empty the car every so often. If a problem happens and you dont fix it, your creating another one.
bmennen07 is offline
Old 08-20-2007, 01:11 PM
LCBlackDep183
LCBlackDep183's Avatar
And how do you expect him to fix it?
Oil getting in the pcv valve is completely normal.
LCBlackDep183 is offline
Old 08-20-2007, 02:32 PM
samseed101
samseed101's Avatar
ORIGINAL: bmennen07
What the **** are you talking about? Do you even have the slightest clue what the problem is? Oil gets sucked up through the PCV valve and spit into the intake all the time! It has always been that way. People just don't tend to notice it until tehy take things apart or until they get problems with the PCV valve. Putting a catch can in is a very common fix for what basically amounts to a design flaw in the system.
But please, enlighten me as to what you think the problem is and how you think adding a catch can will create another problem. Please tell me how YOU think oil is getting into the upper intake.
Old 08-20-2007, 02:40 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
ORIGINAL: samseed101
ORIGINAL: bmennen07
hehehe i want to hear the answer to this one....
FivePointOhh is offline
Old 08-20-2007, 02:41 PM
Texas5.0
Texas5.0's Avatar
ORIGINAL: bmennen07
Silly new guy... samseed is the dude to answer all ourretarded new car peoplequestions. Take his advice.. it's free and better yet correct.
Texas5.0 is offline
Old 08-20-2007, 02:47 PM
FordMustangSpeed
Thanks for the input guys! I'll check the valve asap. Only problem with the catch can idea is that there is no vacuum line attached to the PCV valve. good ol' 5.0's apparently run with an open valve. Last time I checked it ( abouta year ago )I played with the vacuum lines on the intake trying to figure out if the PCV valve would connect toone of them. No matter what I did it always made the car run super bad. But the valve itself may just be jammed. Thanks again
Old 08-20-2007, 03:01 PM
samseed101
samseed101's Avatar
If you've got a 94 Mustang and you don't have forced induction, then you should have a vacuum line running from your PCV valve to the upper intake. If someone disconnected that, then it could cause a number of problems, depending on what exactly was removed and was wasn't. There's a proper way to remvoe the PCV system, but I wouldn't recommend it unless you have a supercharger or turbo.
In your case, if the line is indeed not attached, then you most likely have a vacuum leak which would cause your car to run like ****, or someone did a half *** job and you're gonna have to fix it.
Are you 100% positive that tere is no vacuum line on the PCV valve? The valve sits in the rear of the lower intake manifold ery close to the firewall. It's difficult to get to and see, but it's there. Are you sure you're not looking at something else?
Quick Reply: intake trouble
