Stock Cam Specs
Stock Cam Specs
Can anyone tell me the stock specs on the stock cam? I know it's something along the lines of 443/443 210/210 with a 114 lobe seporation or something, can someone correct those numbers along with give me the exh/int valve lift from the stock cam, thanks.
RE: Stock Cam Specs
.444 lift, 1.7's would increase the lift by approx. .030 lift for a total of .474 lift. They will add a little bit of duration as well because the greater lift the valve will be open slightly longer
RE: Stock Cam Specs
ORIGINAL: Dbeck002
Lift is 0.gay/0.gay
duration @ 0.50" is gay/gay
and lobe seperation is gay.
[8D]
Lift is 0.gay/0.gay
[8D]
RE: Stock Cam Specs
here you go. Hope this helps ya.
http://www.jason.fletcher.net/tech/s...ons/specs2.htm
RE: Stock Cam Specs
ORIGINAL: 1990mustanggt
uberstang1
09-20-2015 06:42 PM
