swapping t5 tailshaft housings
i have two t-5s one is a 92 and one is an 88 with destroyed input shaft.
the 92 someone cracked offthe tab on the 5th gear syncro retainer.
so i swapped over the 5th gear syncro assembly from the 88 to the 92.
Now what i need to know isshould i swap the tailshaft housing also due to the slight difference in the surface that the 5th assembly comes in contact with.
I dont know if the 88 tailshaft housing is different in any other way.
I dont think ill have problems with 5th but will i have any problems with reverse? ( such as the slider assembly that controls 5th and reverse) will the 88 tailshaft housing have a diff design where it would stop the slider from traveling back far enough to engage reverse?
or should i jsut keep the 92 on and roll with it?
RE: swapping t5 tailshaft housings
interesting... i didnt know there was a differance.. id just use w/e makes it work better... and hell, you can swap a tail shaft w. the trans in teh car... so say you bolt it up, and u were wrong.... u can swap it w. the trans in the car...
there is a difference between the 2. the little oil slinger thing on the end of the countershaft gear may not work in the other. there was a site that explained it, i'll try to find it
lol u c ant even see what he said... good ****
dude u gotta meet up w. me and whitefoxgt one of these days... seein that ur prty local and all... maybe a trip to cecil county dragway or somethin
Gary Ugarek
63
12-11-2015 02:01 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
GodAmGT00
03-24-2006 10:24 PM
