window motor
RE: window motor
ORIGINAL: aode06
YOUR MUSTANG
Note: This kit will not fix electrical motor failures caused by worn brushes.
YOUR MUSTANG
RE: window motor
ORIGINAL: chath_brick
mine is doing the same thing...this thread should help
RE: window motor
autozone etc has the window motor repair kits as well, after the reapir the window will FLY up and down.[8D]
if you need the gear, the big white one, you have to count the teeth, as you do in a flywheel
http://www.mn12performance.com/mn12p...t-install.html
here is the real deal
RE: window motor
well i finally found the camera. heres what the motor looks like on the outside:
im just confused because it works fine down lower but when it gets half way up it just stops and does the up and down pulse. all of the teeth on the track in the door look fine, and the window slides fairly easily up and down. any ideas??
