F'ing Cop car
RE: F'ing Cop car
check simple things. drive shaft bolts. was my problem and i experienced the same thing you are. also check tire pressure, H balancer. are all your U joint retaining clips in? check those. if all else i say balance your wheels.
RE: F'ing Cop car
Check your inner and outer tie rods. I had symptoms like what you described and it was my inner tie rods. I went ahead and replaced the rack and pinion because it was leaking. Rack and pinion with inner tie rods was $80.
RE: F'ing Cop car
Tire pressure is at 35lbs in each tire, that was the first thing I checked. Like I said Motor is 100% rebuilt balanced and blueprinted with new harmonic balancer, It revs and idles perfect with no shakes or vibrations. At 70 with the car in neutral it still shakes badly. U-Joints are new, I will check into the tie rod ends and the balancing of the driveshaft I like the sound of an alum shaft though. It may very well be worth $200.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
