302 / 351 differences
RE: 302 / 351 differences
Only stay away from the 351 M if you don't want to do any mods. The 351M isn't necessarily a bad engine. It's just a 351C with dished pistons instead of flat pistons. It also has a milder cam than the Cleveland. The biggest difference between the Cleveland and Modified (It's called a "Modified" because it's just a modified Cleveland) is the heads. The Modified heads have a larger combustion chamber. That with the dished pistons give the 351M a very low compression ratio compared to the Cleveland. You could put a more powerful cam and flat topped pistons, and it will make more power. Also any performance mod that you can bolt onto the Cleveland, you can bolt onto the Modified. But you won't really get the performance gains unless you install Cleveland heads. They have a smaller combustion chamber, which raises the compression ratio. Even so, a stock 351M will put out more power than a stock 302. But I'm not sure you would see that perfomance gain at the wheels because of the significantly more weight from the Modified...unless you modded it.
Eric
Boise Id
Eric
Boise Id
ORIGINAL: MustangLuvr
Eric
Boise Id
Eric
Boise Id
I have to disagree. The Cleveland and the modified are 2 totally different creatures. The Cleveland is actually a small block and the modified is a big block. The measurement from centerline on the crank to centerline on the cam for the cleveland is lower than the measurement on the modified. Almost 2 inches difference in deck height. The cleveland is more of a small block with bigblock type heads. IMO the modified is junk and none of the parts for a cleveland will work in a modified without significant machine work.
Oh yeah, the windsor is an inch wider than a 302 so you will end up needing new headers, intake and a few other things. So be sure thats what you wanna do before you buy it. If it is a Windsor.
ORIGINAL: bossman351
Eric
Boise Id
Eric
Boise Id
Both the 351m and 351c are both in the Ford "335" family. The bellhousing in the modified is the same as the big blocks because Ford wanted to keep using the C-6 trannys behind them.
ORIGINAL: import slayer
I agree with you up until that point. Actually, the cleveland and modified heads interchange. The cleveland heads being much better though.
Eric
Boise Id
Eric
Boise Id
easiest way to tell the diff between a 289/302 and a 351w is looking at the deck height (where the heads bolt onto the block) above the top corner of the timing cover. The distance between the timing cover and the deck on a 302 is only a half an inch or so... whereas its close to 2 inches on the 351w - either that or measuring the width of the intake
BOSSMAN, check out this link....the 4th paragraph down tells you why the M engines had the big block bellhousing pattern.
http://www.projectbronco.com/History..._ford_351m.htm
This would allow Ford to continue putting the larger, heavy-duty 460 C6 transmissions with the new 400 engines.
Finally, the deck height was increased 1.09 inches in order to accommodate the 400s larger stroke.
In fact all of the 351C valve train components (except for the pushrods) interchange with 351M/ 400 engines. The 351M/400 cylinder heads will also interchange with the 351C 2brl heads, although the 351M/400 heads have 78.4cc combustions chamber where as the 351C 2V heads had a 76.2cc combustions chamber.
