is it worth a shot?
Old 08-21-2007, 08:36 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
Default RE: is it worth a shot?
to cool your fuel line
2 kwik is offline
Old 08-21-2007, 08:42 PM
cleanfitty
cleanfitty's Avatar
besides.. the pressure would go right through the air filter and out to the open. it wouldn't be "forced" like a closed system...
cleanfitty is offline
Old 08-21-2007, 09:13 PM
samseed101
samseed101's Avatar
ORIGINAL: TwotoneVert
Compressed air has moisture in it, I wouldnt think it would work to well. Forcing unmetered, unfiltered air into your intake would not be a good deal.
It's not unmetered because he's spraying it before the MAF. This may have a slight affect actually. I think that the rapidly expanding air may "freeze" the MAF and make it think more air is flowing in. So it may run a bit richer and get slightly more power. Not sure if it would work in reality though.
samseed101 is offline
Old 08-21-2007, 09:28 PM
tooslow5.0
tooslow5.0's Avatar
why dont you just plumb your airconditioner vent into your intake and get clean 40 degree air into your engine. should be good for at least 15 hp. never mind the fact that spinning the compressor eats up 15% of your hp. -----look if you wana do that then buy one of these, itll work better than a compressor and add a smidge of positive manifold pressure. not to be an ***, but your idea will do nothing good for hp.
www.electricsupercharger.com/
tooslow5.0 is offline
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
showoffzx2
4 Cylinder NA and Turbo
09-14-2015 08:40 PM
robjh22
Suspension
09-08-2015 12:47 PM
09-08-2015 11:50 AM
Quick Reply: is it worth a shot?
