TPS voltage
RE: TPS voltage
ORIGINAL: ahittz24
Try to adjust it. Loosen the 2 screws and set it as close to .99v as possible with key on engine off (KOEO)
the .99 or .98v thing is a myth
Also, use the DVOM to test the TPS. slowly open the throttle and observe the TPS voltage. make sure it rises smoothly, and has no dead spots
RE: TPS voltage
ORIGINAL: AdderMk2
as long as the TPS is between .73v and 1.ov, the computer will take care of the rest....
Also, use the DVOM to test thr TPS. slowly open the throttle and observe the TPS voltage. make sure it rises smoothly, and has no dead spots
ORIGINAL: ahittz24
RE: TPS voltage
ORIGINAL: 2 kwik
you replace it!
ORIGINAL: FivePointOhh
what would you do in the case there is dead spots? just move it around some more to see if it fixes itself or does that mean tps is bad or what?
ORIGINAL: AdderMk2
ORIGINAL: ahittz24
