How do you "Pull Codes"....
Old 08-22-2007, 02:13 PM
blahman20
blahman20's Avatar
Default How do you "Pull Codes"....
I'm having an idle problem....sometimes it will just start idling at 1800 by itself, then a few minutes later it will come back down when I stop again. I think it's MOSTLY happening when the engine is already warmed up, but it happens at different times. I know it can be a few things...IAC, TPS etc....however I was just curious how do I pull codes? Do I need the Code reader thing (lol)....and any ideas on my problem?
Also today when I was driving it started to shake a bit, like it was missing, and the rpm's were going up and down!! then 2mins later I took it around the block and it idles good and didn't shake at all....weird.
Also on cold starts...it idles then falls then idles then falls then idles then falls then eventually it will stay at around 900....until it gets more warmed up and it starts to idle way up again.
blahman20 is offline
Old 08-22-2007, 02:30 PM
Hawk
Hawk's Avatar
Default RE: How do you "Pull Codes"....
http://www.muscularmustangs.com/test1.php
That should do it for you.
Hawk is offline
Old 08-22-2007, 03:02 PM
TwotoneVert
TwotoneVert's Avatar
Thats a good link, thanks Hawk.
TwotoneVert is offline
Old 08-22-2007, 03:04 PM
Hawk
Hawk's Avatar
Not a problem.
Hawk is offline
Old 08-22-2007, 03:06 PM
blahman20
blahman20's Avatar
that makes no sense to me but thanks anyways.
Old 08-22-2007, 03:29 PM
Joel5.0
Joel5.0's Avatar
You may also want to check DIY KOEO/KOER self-tests ......
Joel5.0 is offline
Old 08-22-2007, 06:51 PM
Hawk
Hawk's Avatar
ORIGINAL: blahman20
If that doesn't make sense than you might want to consider purchasing a code scanner for like $30 at your local parts store.
Hawk is offline
Urambo Tauro
10-05-2015 09:37 PM
Mr. D
10-01-2015 01:03 PM
microgt
08-20-2015 07:12 AM
Casper98GT
02-20-2005 12:30 AM
Quick Reply: How do you "Pull Codes"....
