Need MAF Help badly
Old 08-22-2007, 08:52 PM
sn95aod
sn95aod's Avatar
Default Need MAF Help badly
Ok so here is the story. My brother has a 93gt and he let it sit for about 2 or 3 years. So last week we put a new starter on, new plugs, msd wires cap and rotor and a cold air intake, aluminum tube inside fender kit. Now when he tries to rev it or drive it, as soon as it hits 2000 rpms it bogs down and acts like it doesn't have any power. It actualy bogs down so bad that it feels like you barely have the gas pedal down, it alsmost doesn't want to go over 2000 it goes so slowly up the rpms. I tried adjusting the timing and it just sounds like it backfires in the intake, it is wierd. I unplugged the MAF and magically the car runs like nothing is wrong. No other mods are done to the car except for weld in flowmasters. Is it a bad MAF or is there just too much air coming in through the intake or am i just crazy?
THANKS!!!!
Brad
sn95aod is offline
Old 08-22-2007, 09:03 PM
samseed101
samseed101's Avatar
Default RE: Need MAF Help badly
Clean the MAS wires and check to see if they're damaged. Or at least check to see how many spiders built webs on them 3 years is a long time to sit.
samseed101 is offline
Old 08-22-2007, 09:08 PM
sn95aod
sn95aod's Avatar
So just clean the MAF connecting wires, you mean the actual connection right? You should see the amount of rat **** on the intake manifold it is almost too funny. Do you think that theMAF could have gone bad from sitting?
sn95aod is offline
Old 08-22-2007, 10:22 PM
samseed101
samseed101's Avatar
No, I don't mean clean the conenction (although that is a good idea) I mean physically remove the actual sensor itself. You're most likely going to need a security torx bit to get it out size 20 if I recall correctly.) Or you can take off the whole MAF and leave the sensor attached.
The sensor itself will ahve to VERY fine / tiny wires hanging down. Those are the ones you want to clean. To clean them, just get a can of MAF sensor cleaner from a parts store and spray th **** out of them. i suspect that after all this time, there must be some orety nasty stuff on the wires.
Although I don't often recommend it, if it's bad enough you can spray some on a q-tip and LIGHTLY clean the wires.
While you're at it, check and make sure the "spout conenctor" is still in place. Chances are it is, but it's worth checking anyway. That should be very close by, along the fender.
Old 08-22-2007, 10:23 PM
sn95aod
sn95aod's Avatar
Any other ideas?
sn95aod is offline
Old 08-22-2007, 10:26 PM
samseed101
samseed101's Avatar
To remove just the sensor itself, remove these screws:
It will pull out the two MAS wires that are normally in this tube when installed:
Once it's out all the way, it will look like this. This is what you want to clean:
Old 08-22-2007, 10:28 PM
samseed101
samseed101's Avatar
ORIGINAL: sn95aod
Any other ideas?
Not too many offhand. Just check and clean the MAF / MAS. Then check the spout conenctor to make sure it's there. Wouldn't hurt to clean the IAC (idle air control) while you're at it. And then check EVERYWHERE for vacuum leaks. I'm sure those old rubber lines are about ready to crack.
Old 08-22-2007, 10:29 PM
Slimboyfatty
Slimboyfatty's Avatar
look and see if the vacuum line from the CAI to the oil feed kneck is connected. Just like 2 weeks ago I had the same thing happen to me we hit a record high 113 degrees out here in MO and one of the clamps broke off and that vacuum line was unhooked. It fixed my problem for a little while but unfortunately the problem came back and it was my MAF sensor and I had to replace it. I work at Oreilleys auto parts though cuz im only 18 so it was like 30 bucks to fix. Hope I could help!
Slimboyfatty is offline
sn95aod
sn95aod's Avatar
i just saw your post after i replied. Thanks for the tips. Like I said i just tried to adjust the timing. also the timing is a little funky i tried to adjust it, it says that it is at like twenty for some reason. when i tried to take it down to 14 it doesn't want to run. What do you think could be causing that? or am i reading it wrong? I took out the spout connector and put the clip on the first plug wire which is coming from the plug that is all the way towarsds the front of the car on the passenger side. could the balance be off for some odd reason or am i doing ti wrong?
sn95aod is offline
Old 08-22-2007, 10:32 PM
sn95aod
sn95aod's Avatar
I meant balancer
sn95aod is offline
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: Need MAF Help badly
