brake boost question
Old 08-24-2007, 08:05 PM
dcp8750
dcp8750's Avatar
Default brake boost question
I believe I have brake fluid in the booster, does this mean that the whole master cyclinder is bad or just maybe the gasketbetween the cyclinder and booster is bad??????????
dcp8750 is offline
Old 08-24-2007, 08:41 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: brake boost question
What makes you think so?
PRO50SC is offline
Old 08-25-2007, 10:19 AM
dcp8750
dcp8750's Avatar
which part? I have a vacuum reservior installed so I have a hose running from the upper intake to the reservoir, then a hose back to the booster. I have found fluid in the vacuum line hose that runs back to the upper intake. So there is fluid coming out of the booster into the reservoir back into the upper intake. Unless there is supposed to be fluid in the booster, but I dont think there is supposed to be.
dcp8750 is offline
Old 08-25-2007, 11:32 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
What year car? What's the need for the extra vac res? The only way brake fluid can be getting into the booster is thru the back of the master cylinder where it bolts up. Pull the master cylinder forward and see if it's wet back there.
PRO50SC is offline
Old 08-26-2007, 07:25 AM
dcp8750
dcp8750's Avatar
its 1995 327 cobra, with v-2. I was told thruresearch that I needed the reservior, plus before the reservior I had zero brakes, now my brakes are awesome. but I will pull the master off the booster to check. Nothing will leak out when I detach the two correct????
dcp8750 is offline
Tivo304
08-28-2023 12:19 PM
Galactic
04-29-2019 02:56 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
Quick Reply: brake boost question
