MAF?
MAF?
Okay, I have a 1989 mustang gt convertible. My only mods are BBK cold air induction, BBk headers and o/f h-pipe, and flowmasters. I want a new MAF, but I don't know much about them. Basically tell me all about them. I need help deciding size, brand, etc. Please help.
Thanks
Thanks
RE: MAF?
Well I do not have a MAF car but I do know a but about it. Basically your car has a Mass Air Meter that is calabrated to factory 19 lb injectors I am not sure how many mm stock is, but it is totally useless going to a bigger MAF unless you change out the EGR spacer,and intake to a larger MM bore. And that usually does not gain any HP unless you need more air to your engine. For example if you installed a pair of heads and upper and lower intake with some high ratio roller rockers your engine will need more air to deliver it MAX HP. Stick to your factory on unless you are planning on going with some mods
RE: MAF?
ORIGINAL: schwindty
RE: MAF?
If you are keeping the stock TB, then the TB is not going to allow anything more than 60MM, but if you even upgrade to a 65 or 70MM, the 73MM will still provide adequate air flow... I would go with the 73, it is better for your app, and will suit your needs nicely.. Let me know how it goes, I am doing the same thing.
jwog666
12-27-2021 08:09 PM
stangin1996gt
09-21-2015 11:01 AM
