Fuel pump won't turn on...
Old 08-27-2007, 11:31 AM
jrt1990
jrt1990's Avatar
Default Fuel pump won't turn on...
Hey guys recently I've been taking out the old interior in my Mustang and getting everything ready for a mass air conversion but for some reason now my fuel pump won't turn on. Everytime before I start it, I turn the key to ON, wait for the fuel pump to turn on, then start the car, but now it doesn't turn on and of course it doesn't start...any suggestions?
jrt1990 is offline
Old 08-27-2007, 11:32 AM
jrt1990
jrt1990's Avatar
Default RE: Fuel pump won't turn on...
And I also disconnected one component of the computer but it has been reconnected.
jrt1990 is offline
Old 08-27-2007, 11:40 AM
WhiteWindsor
WhiteWindsor's Avatar
First thing i would do is trace your wires and make sure none are damaged and everthing is plugged in good.
WhiteWindsor is offline
Old 08-27-2007, 11:41 AM
samseed101
samseed101's Avatar
Check the trunk to see if the inertia switch is tripped / unpluged / damaged.
samseed101 is offline
Old 08-27-2007, 11:42 AM
samseed101
samseed101's Avatar
What is the 1 component that you disconnected and reconnected?
Old 08-30-2007, 01:15 AM
jrt1990
jrt1990's Avatar
I've checked all my wires including the ones under the drivers seat and they all look fine. I disconnected a littlebox that had a 2 or 3 wires coming out of it from the computer that has a metal tab that appears to ground it to the frame with a screw.
jrt1990 is offline
Old 08-30-2007, 08:54 AM
samseed101
samseed101's Avatar
Yes, but what about the inertia switch in the trunk? You still haven't said if you checked that or not.
Old 08-30-2007, 11:46 AM
jrt1990
jrt1990's Avatar
ORIGINAL: samseed101
No I havent checked that, where is it? and is there any reason that would just turn off by itself?
jrt1990 is offline
Old 08-30-2007, 12:14 PM
samseed101
samseed101's Avatar
It doesn't take much to trip the inertia switch. Small accident, pothole, lunar eclipse, etc.[8D]
Look in the trunk near your driver's side taillight. You should see a small cutout where you can reach a finger through there. Or you cna just pull the carpeting back. There will be a relaw / switch that will look like this. Check the connection on the bottom to make sure it's okay. Also press the big red button on top to make sure it's reset.
Old 08-30-2007, 02:59 PM
Cobra77
Cobra77's Avatar
Yeah..inertia switch + the fuel pump relay (under the drivers seat) is pretty much what commands the fuel pump. You could try a new relay, or first check for voltage at the fuel pump harness when you hit the key.
Cobra77 is offline
Quick Reply: Fuel pump won't turn on...
