my set up?????
RE: my set up?????
And that not's a standard tire size. First number is width in mm. Second number should be height but it's measured as a percentage of the width. So on a 275/50, the height is 50% of 275mm + the rim size. That tire in the pic is not 645% of the width.
RE: my set up?????
ORIGINAL: 89 mustang
ok then 10s Iam not going to see! but now I got the mounts installed and I was wondering is hard to rebuild the posy unit?[/align]
I SWEAR I DID NOT KILL NICOLE SIMPSON, THE GLOVES DONT FIT!!
RE: my set up?????
THE MOST IMPORTANT THING TO REMEBER ARE THE SHIMS LOCATION.
One will go to the left, or two on the left, the others on the right, dont mix LEFT AND RIGHT up, I paired em up , cleaned em and wrote the location on them with WHITE OUT
ALSO DONT USE BRAKE FLUID ON THE NEW CLUTCHES, it will hurt the glue they are made with, instead put some gear oil on them
RE: my set up?????
^^why would anyone use brake fluid?
OP, where did you get a tire with that size on it?? I have never seen a metric tire dimensioned out like a English tire. Example 31"x10.5x15=true tire size. metrics are sized like FullAuto says.
RE: my set up?????
aode06[/b]thanks man I finished that differential last night I dint get the chance to take it for a spin but ill keep you posted [/align]
