TrickFlow Kit
RE: TrickFlow Kit
go with 1.6 rockers, there have been tests done that the 1.7 loses some of the low end the 1.6's have.
comp XH270 cam
holley upper and lower
afr 165's
sounds like an awesome combo (I'd recomend that cam, but you can go with what ever you want)
matt
comp XH270 cam
afr 165's
matt
RE: TrickFlow Kit
Well if you get the right cam with the right duration, you should be able to keep the bottom end, and gain a lot of mid and top with the 1.7's... This is why the stock cam works so well with the 1.7's because of the duration match.. The stock cam is great for bottom end, I am not touching my cam, and doing about the same mods.. 1.7's Trick flow up/low and AFR 165's ... 58cc versions..
RE: TrickFlow Kit
I may keep the stock cam depends on its condition though. I'm not sure why one oy sets of valves don't operate. So when I have so time I'm crank the engine over when the intakes and valvecovers off to see if the pushrods are moving. How come you are choosing the 58cc heads, won't that raise the compression more? I'm just wonderinh how much it raises it. Thanks for all the help guys
RE: TrickFlow Kit
Yes it will raise the compression. It will raise it to about 9.65:1 CR... From a 9.0:1 So It will change noticably, this makes for more compression in each cylinder which = more power! the 62cc's are good too though, just not as high of compression.
RE: TrickFlow Kit
ORIGINAL: RR69
Will rinning the 58cc heads make a noticeable amount more power? Do you have to run higher octane fuel for the 9.65:1, or can you get away with only midgrade, just wondering.
jwog666
12-27-2021 08:09 PM
