TRANNY GURU'S AOD TO C4?
RE: TRANNY GURU'S AOD TO C4?
No mods are needed. You can use your existing crossmember and driveshaft. However, ther are two different C4s. One has a larger bellhousing than the other. Make sure you know which one you have. If you have the larger bellhousing, you can re-use your AODs flexplate which is a 164 tooth 50 oz flexplate. If its the smaller bellhousing, you'll need a 157 tooth 50 oz flexplate.
treesloth
09-28-2015 07:03 AM
jaiidutch
09-14-2015 10:29 AM
