Cam Help
Cam Help
I have been doing a lot of research on which cam Im going to put in my new setup. I think I have come a conclusion and I wanted you guys opinion on the cam that I have picked and if there is a better cam for my setup.
My setup:
Explorer 302
GT-40P Heads
Polished swirled valves 1.84/1.54
Mild port job
Matched Crane cams springs and retainers - 44308-1
1.7 Cobra Roller Rockers
Powermax 2031 Cam - CRN-444225
Lift: 513/529
Duration: 214/220
Explorer Intake
70mm TB and EGR Delete plate
Cold Air Kit
My setup:
Explorer 302
GT-40P Heads
Mild port job
Lift: 513/529
Duration: 214/220
Explorer Intake
Cold Air Kit
RE: Cam Help
1.7 rockers will put you at over .600" of lift, you had better make sure you have the piston clearance for that, or it will be quickly made for you
Other than that I agree with My77 (write this moment down) it looks like you have put a lot of thought into your selections.
RE: Cam Help
ORIGINAL: FullAuto
1.7 rockers will make it .545/.562.
ORIGINAL: MadMan@TheWheel
RE: Cam Help
ORIGINAL: OnyxCobra
I would go with a cam that has more duration.
And just for the record, I'm 99% sure the Crane 2031's advertised lift is with 1.7 rockers.
RE: Cam Help
Okay, splitting hairs. .542/.562 is still an area of concern with spring and pistons, yes?
RE: Cam Help
ORIGINAL: FullAuto
