Rocker arm ratio
Old 09-01-2007, 01:29 PM
FullAuto
FullAuto's Avatar
Default Rocker arm ratio
This has came up several times in the past few weeks so let's clear this up. SBF cams are generally rated with a 1.6 rocker. So when you see the FMS B cam with .480 lift, the lobe lift on the cam is .300. Take that .300 and have a 1.6 rocker and you get .300 x 1.6 = .480. With a 1.7 rocker you'd have, .300 x 1.7 = .510.
An E cam with .498 lift has a .31125 lobe lift. Now realize that the advertised numbers in catalogs are also generally rounded off numbers. The lobe is probably actually a .311 lobe. With a 1.6 rocker that would make it .4976 and they could possibly round to .498. But it also may actually be a .31125 lobe. This info shouldn't be hard to find, but I'm too lazy to look. Anyway, with a 1.7 rocker on an E cam, it would be .311 x 1.7 = .5287 or .529. If it really has a .31125 lobe, it would be .31125 x 1.7 = .529125 or .529 lift still.
The TFS site actually lists the lobe lift and the lift with 1.6s. http://www.trickflow.com/product/cam..._cams_ford.asp
As you can see,a TFS Stage 2has a lobe lift of .339/.352. With 1.6s this makes it .5424/.5632 and they round off to .542/.563. With a 1.7 rocker, this cam would be .576/.598.
Also, just because SBF cams are generally rated with 1.6 rockers doesn't mean everyone is. They are rated with whatever they came with from the factory. Most SBC stuff is rated with 1.5s, big block stuff with 1.7s, etc.
Clear as mud?
FullAuto is offline
Old 09-01-2007, 01:32 PM
FullAuto
FullAuto's Avatar
Default RE: Rocker arm ratio
When you are trying to figure out how to convert from 1.6 to 1.7 ratio and you don't know the lobe lift, you take the advertised lift with 1.6... DIVIDE by 1.6 (to get the lobe lift), then MULTIPLY by 1.7.
FullAuto is offline
Old 09-01-2007, 01:58 PM
stang8689
stang8689's Avatar
thanks for the info
stang8689 is offline
Old 09-01-2007, 02:01 PM
my77stang
my77stang's Avatar
its so easy for us that understand it, sometimes its just as easy to forget others just dont know[8D]
my77stang is offline
Sixer4Life
10-12-2015 04:26 AM
UrS4
10-03-2015 06:23 AM
UrS4
09-30-2015 10:13 AM
uedlose
09-30-2015 08:01 AM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: Rocker arm ratio
