fuel upgrades?
fuel upgrades?
i have a 1995 cobra with e cam and edelbrock performer heads, 75 mass air metere and fender well cold air intake ... with the 1993 cobra computer, msd ignition, ... i wanna get a procharger what fuel upgrades should i get ?
RE: fuel upgrades?
and it also depends on how many psi ur gunna run. Like 1BADASS said, 24's, 190-225lph fuel pump, high flow filter, matching MAF, ECU upgrade (chip,module) and maybe some nice aeromotive billet fuel rails...and a good adj. fuel reg. Make sure its fully adjustable and not just a high flow one. U want to be able to fiddle with it the way you want.
RE: fuel upgrades?
i already have the 24 pound injectors what do u guys think the 42? or even less? should i get a bigger pump or will the stock pump be fine with the inline fuel pump that come with the superchargers.
RE: fuel upgrades?
go 42# and a blow thru pro m maf they only cost like 280 and they make it easy to tune. and the kit comes with a fuel pump so just get a adjustable fuel pressure reg and youll be set as far as fuel goes. be ready for a hard install if your putting in the supercharger yourself, just so you know.
09-17-2015 07:32 PM
