275 or 315
275 or 315
275/40-17 or 28X10-15 Hoosier drag slicks
will 315/35-17 fit?
gonna put weld draglite 15x8 in the rear and 15x3.5 in the front
[/b]may go prostars still same size. will i need spacers if so for which ones[/b]
[/b]i need some advice on this.
[/b]
will 315/35-17 fit?
[/b]
RE: 275 or 315
ORIGINAL: justakid
will 315/35-17 fit?
[/b]
will 315/35-17 fit?
[/b]
What power are you putting down? What gears? Your other two choices are different height in case you didn't know.
RE: 275 or 315
just ignition and tune up stuff.
i have stock gears but may install either 3.75s or 4.10s in the future.
pretty much stock it's gonna have air intake and other **** in a couple months.
275/40-17 or 28X10-15 Hoosier drag slicks?
i'm guessing 28X10-15
RE: 275 or 315
for the mods you have you can run a 255/50/15 et street and youll never be able to break the tire loose. even after the gears that tire will be plenty because your not making jack for power. if you want a 275 just for looks then get a 275/50/15
09-01-2015 08:16 PM
UT04GT
29
02-25-2005 12:28 AM
