smog delete
smog delete
ok when i was rebuilding the car are the wreck i deleted my smog pump and EGR... now the car runs rich and has an engine code... i'm sure the code just says its right and that the egr isn't functoning properly...
any ideas what would make it run rich? or has any one else had this problem after a smog delete?
RE: smog delete
i know that, but that shouldn't effect the way it runs should it? and whats the easiest way to fix the problem with ouy buying one of those little things off ebay
RE: smog delete
no i haven't had a chance to check anything, but i know it's sealed all the way, i used a block off plate with RTV... i removed both the smog pump (along with all the tubes) and the egr... i do have a slight exhaust leak where the smog pump tube connected to the h pipe but it's not bad enough to cause and issues
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
