Cooling Help
RE: Cooling Help
ORIGINAL: samseed101
Sorry, I can' t offer you much assistance here. I do run an external trans cooler only with the stock radiator. This is with an AODE and a shift kit. The engine coolant temp is fine (as measured by my tweecer) but I can't give you exact numbers on the tranny temp. It seems to feel fine though.
RE: Cooling Help
I'm putting a ****load of stress on my engine and the temp seems to hold up fine. My situation...
I have a stock radiator on a supercharged engine. It gets HOT in there. Yet the temp stay's right where it should be. On top of that, I have an air-to-air intercooler in front of the radiator (24" by 12") so that blocks some of the airflow. I also have the power steering pump cooler and the aftermarket tranny cooler up there.
Even with all of that, the engine stays right where it should and everything else stays cool as well, even on hotter days. Fan rarely has to come on unless I'm in traffic for extended periods of time.
In other words, I think you'll be fine.
RE: Cooling Help
at the local speed shop they have a fluidyne and summit, basically the same thing. all alluminum design, only thing missing is painted on fluidyn logo......everything else looks the same, size wise and everything. save yoruself a lil money
RE: Cooling Help
Nah, Im just going to go with the Fluidyne rad & the Taurus fan.
And BTW, samseed, I think Im back. Im going to be doing lots of work on the ride soon and I might need some help from you tards lol
