Need some serious advice/opinions!!
I am buying a cobra, I have found two one is a 95 that is a hard top convertible/ only 499 made $9,000. and the other is a 1997 convertible $7,600. The 1997 is completely stock with 93,000 miles. the 1995 has this dones to it
afr 165 heads with stock cobra roller rockers
trick flow stage 1 cam
new ford racing timing chain
pioneer sfi balancer
trick flow street heat intake
C&L inlet tube
pro-m 75mm MAF cal'd for 30# injectors
30# injectors
BBK underdrive pullies
Fluidyne radiator
BBK shorty headers for 87-93BBK o/r x-pipeedelbrock catback
performance distributors(pd) computer distributor
pd livewires plug wires
pd ignition coil
pd ignition module
trans/rear end
T56 trans with approx 4k miles on it
fidanza lightweight flywheel
frpp clutch quadrant/cable
king cobra clutch
cust aluminum driveshaft
3.73 gears
frpp 31 spline axles
03 cobra diff
arp diff studs
summit rear end aluminum cover
royal purple fluid changed 300 miles ago
Brakes
braided front hoses
03 cobra calipers in front with good pads
brand new rear calipers/pads/rotors--all oe ford
suspension
maximum motorsports(mm) front coil overs with 10" 300lb springs
mm caster/camber plates
mm bumpsteer kit
mm offset front control arms
mm ride height adjustable rear lower control arms
hp motorsports panhard bar
eibach pro-kit rear springs
tockico illumina 5 way adjustable shocks/struts
steeda full length subframe connectors
frpp strut tower brace
steeda 4 pt bolt in roll bar
steeda ultra lite 1 17x9" wheels with good dunlop direzza 255/40/17 tires
interior
arizen racing seats on stock non-power seat sliders
new black carpet
new oe shift boot
03 cobra shift ****
The thing is that the car fax report says it was in a wreck, a minor collision. I am sure this would be worth some money in stock form because it is so rare but since this guy changed evrything in it even the seats it is probably worth no more than a regular gt right or wrong? And to have all of this stuffdone alrady you don't know the quality of installation. Anyway myquestion is what would you guys do??? all opinions welcome!! Thanks
C&L inlet tube
30# injectors
Fluidyne radiator
pd ignition coil
pd ignition module
trans/rear end
king cobra clutch
3.73 gears
03 cobra diff
arp diff studs
Brakes
braided front hoses
suspension
mm bumpsteer kit
interior
new black carpet
new oe shift boot
03 cobra shift ****
RE: Need some serious advice/opinions!!
Go for the 95 and ask if he has any of the original parts for it. Just in case you would want to put it back to stock but it sounds like it has a great parts lists. Test drive and take it to a reputable shop for a mechanics opinion. Good luck.
the 1995 has 120,000 miles on it, 9k on heads and 4k on tranny. it has a 4 point roll bar. i would like to do the stuff myself, but i was just thinking that this would be a collectors item. you think that this would be a highly sought after car because the low 499 released? i was alsmot thinking of changing it back to stock and buying a junker gt and putting all the parts on it. what you think about the collectors side of it??
i've never heard of a hard top convertible 95 that came from ford...
i'd assume if it was really the case, there would be ford documentation of it.
otherwise, for 3k any trim/body shop can do that
Hmmm, yea i dont know about the hardtop vert thing??? But if it is true it would probably be worth alot more in stock form. Even so, 9k seems like a good price for the 95
