WhiTch 1..?
WhiTch 1..?
Which would you guys go for...? o to add i have a fairly stock 5.0 with 3.73's.
http://cgi.ebay.com/ebaymotors/COMP-...QQcmdZViewItem
OR
http://store.summitracing.com/partde...ew=1&N=700+
a and whats the difference between roller tappet and flat tap..?
OR
RE: WhiTch 1..?
The difference is pretty significant. Do you have a engine yet? Kinda hard to believe you would not know what cam to get with your engine, assuming you had one. You have roller blocks and non-rollers. Rollers use hydraulic roller cams and hydraulic lifters. Non-rollers use flat tappet style cams and have mechanical lifters. There are a few critical differences in blocks when its time to decide on parts to buy for it. What engine do you have, year and block?
RE: WhiTch 1..?
IMHO, You'll be in trouble with that Comps roller if you have an automatic.
I think you'll need some convertor, not much, to really get any benefit from that cam.....
Manual trans and you'll be ok..........
RE: WhiTch 1..?
most people will tell you your pissing your money away on a cam if you still have stock heads. IMO you could grab some 1.7 rocker arms, or something along the lines of a steeda #19 or B303 cam (the 19 was the .480 lift no?).
beware, either of those are pushing your stock springs to their limit though
RE: WhiTch 1..?
i agree with my77stang you will just be **** in the wind. however, if have to get one get the steeda #18 not the #19 they are meant for 94/95gt. the lsa on the #19 is 115* you more than likely want the #18 with a 112* lsa for a rougher lobe. i assume that what you looking for a good lobe.
