not sure what this sound is
RE: not sure what this sound is
ORIGINAL: ACE
I would say go over your bolts on the driveshaft again just to make sure its tight. If the noise is only in 1st gear and not when you rev it or rev while sitting still, then it has to be in your driveshaft. Do you have the splines correctly lined up?
ive located my probelm. the ebrake cable that runs down the driveshaft hump....well right when it makes the first 90* bend the bracket is not actually spot welded anymore. i never noticed before because when i was under the car the cable was always pulled tight so it looked correct but when i went to drive away it was hanging and i would slap against the floor pan (weird!?) anyways, i took it over to a friends this afternoon and threw on two welds and now shes back to normal AND there is an added bonus. my ebrake cable only sometimes would pull tight and i would have to try a couple times before it would actually hold (i always ended up leaving in gear because of this) now the e brake holds all the time. BYAHHHHH
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
