How can i make this work?
i have this c&l power pipe but i dont want to use it w/out the stock air box or a canister filter. what do i need to get so i will have a fenderwell induction? Thanks
http://www.cnlperformance.com/76mm_86-93.html
RE: How can i make this work?
Your cone filter mounts at the end of the MAF. Make sure you have a MAF calibrated to your injector size. If you want fenderwell induction, you need something different than what you have. If you bought this piece because you though it would allow you to run the stock MAF with larger injectors, that is not going to work very well. Trust me, I bought that piece of crap too, and then had to buy something else after.
i dont want to use a cone filter either. i like the look of the c&l pipe but if it is going to be more trouble than its worth then is there any other setup that looks good. i dont want chrome or polished. i have the maf but i need some form of tubing to get to the fenderwell. thanks
sorry i hit the post button twice
this is the cai I'm running, I got it off ebay and the guy I bought it from said he had it mated to a 76mm maf at one time.. thats the reason I got it mainly cause I want to upgrade the c&l setup like you
have.
Its plastic also and acutally looks pretty good under the hood, doesnt' get too hot either.
http://store.summitracing.com/egnsea...803+115+400105
have.
